VPEX Auto-Configuration clears the ring when it detects the ring need to be re-formed. It destroys the ring and makes the ring to converge into two independent configured cascades. All ring related data struct will be cleaned. It happens only when ring is Severed.
No action required - Notification message only.
Notice
Clear the ring from ring node %slot% on port %port%
| Name | Type |
| slot | Slot |
| port | SlotPort |
